sammydag
Apr 02, 2018Aspirant
satelite not connecting
I did the fire ware update and not one of my 2 satatile is not working. the light on top is blinking white. I have tried to resync the satelite, push the reset button, powered off and on. I am lost o...
Apr 02, 2018Guru - Experienced User
Did you reset the router and set it up from scratch first. Then setup the Satellites>?
- sammydagApr 04, 2018Aspirant
How do I rest the router and satelites?
- sammydagApr 05, 2018Aspirant
I have tried to reset just my satelite by pushing the reset button on the back with a paper clip for 7 seconds. No change. Will I have to do the same method to the rounter and the other satelite that is working?
