Pesandbe
Aug 08, 2021Follower
Satelite not syncing
By removing the entry for my sattelite under Home Devices and Clients sync worked as supposed.
Aug 08, 2021Guru - Experienced User
What model Orbi system do you have?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
