jimbojames79
Sep 12, 2018Apprentice
Satelitte backhaul regular dropout
Hi,
I've noticed when gaming or transferring files my a pc linked to the satelitte that the connection drops out regulary every minute or so for about 2-3 secs
Windows doesn't notice but if ...
Sep 12, 2018Guru - Experienced User
What FW is currently loaded?
How is the satellite connected? Wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
jimbojames79
What FW is currently loaded? 2.1.4.16
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris VMDG505 / TG2492LG-VM distributed
How is the satellite connected? Wired or wireless? Wireless Connection Status = Good
What is the size of your home? Sq Ft? Don't know medium sized UK house
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. 33ft 1 brick wall
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. 1 and 48
Any Wifi Neighbors near by? If so, how many? 7
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Already done for previous (many) issues.
The orbi never notices the dropout nor does windows. I can visibly see the dropout when running wifi analyser software.
Thanks
James
- FURRYe38Sep 12, 2018Guru - Experienced User
Can you move the satellite a bit closer to the router and see.
This only is seen with the satellite? I presume if you turned off the satellite and tested directly with the router, wifi is stable?
Might try a factory reset on the satellite and set up from scratch and re-add it and test...
- jimbojames79Sep 12, 2018Apprentice
If I move it closer, the issues where the devices contantly hop from router to satelitte occur.
There are no similar issues on devices connected to the router - xbox and Switch play fortnite fine.
How do I do a factory reset on the satelitte?
I would test the satellite closer just for testing this configuration. Then move it back.
Press in on the reset button in back with a push pin or paper clip, hold it until the top led turns on Amber, then let go. Wait for the top led to slowly pulse WHITE, then press the sync button on the router then sync button on the satellite. Wait for the top to turn on BLUE.
- st_shawSep 12, 2018Master
Orbi and Windows never notice it because there is not an actual "dropout."
The "dropout" you see in your WiFi analyser software does not mean the backhaul is dropping. There was a lot of discussion about this issue on here many months ago, and there was a lot of misinformation and wasted time.
What you see is normal and simply means your scanning software missed a packet from the Orbi. This happens because your WiFi adapter and scanner can only operate on a single band and a single channel at any one time, and is rapidly scanning through all bands and channels. Occasionally it will change channels before getting a response from the Orbi backhaul.
The backhaul SSID is hidden, and it takes special gear to reliably track hidden SSIDs. If you buy a WiFi adapter and analyzer software that let's you lock onto a fixed WiFi channel, and lock it onto the backhaul channel, you will see there are no dropouts. I've done this.
- jimbojames79Sep 12, 2018ApprenticeOk seems reasonable, but why does it happen then?
- st_shawSep 14, 2018Master
It's hard to say.
To truly test the backhaul do a throughput test using iperf3. It's a great tool to measure your WiFi performance also. You can download it from here: https://iperf.fr/iperf-download.php
You run it in server mode on one machine and in client mode on a second machine.
On the server server: ./iperf3 -s
On the client (assuming the server is 192.168.1.10): ./iperf3 -c 192.168.1.10 -t 60 -P 8 -R
Connect the server to a LAN port on the router. Connect the client machine to a satellite LAN port. This will test the backhaul only.
The command will give you a printout every second showing the effective throughput between the machines. If there is any disconnection it will be evident in the numbers. You can run the test as long as you like by changing the -t parameter. Using -R sends data from the server to the clent. Leaving off -R goes the oppostie direction.
After testing the backhaul, you can repeat the test with the client connected to WiFi.
