Salvare
Oct 22, 2021Follower
Satelitte compatible with RBR50v2 available ?
Hello community, Can you please tell me what reference of satellite is compatible and available for RBR50v2 Orbi router ? Thanks in advance, S.
CrimpOn
Oct 22, 2021Guru - Experienced User
All of the original Orbi satellites will work with an RBR50V2
- RBS50
- RBS40
- RBS20
- RBW30
- RBS40V
Satellites from other product lines will not (Pro, AX, "10" series)
pkgadd
Oct 26, 2021Luminary
...plus the outdoor RBS50Y.
- FURRYe38Oct 27, 2021Guru - Experienced User
Also EX 7500, 7700 and 8000 extenders are supporting as well.
- pkgaddOct 27, 2021Luminary
Do these plain repeaters really integrate seamlessly into the orbi mesh (I don't think so)?
Obviously you can use them the extend your wireless network (orbi or not), but I wouldn't classify them as mesh satellites (which means you don't get central configuration, client steering and neither get access to orbi's wireless backhaul, repeating the fronthaul instead). These can still make sense in an (otherwise-) orbi environment, but they're not on par with orbi satellites.
- FURRYe38Oct 28, 2021Guru - Experienced User
I didn't refer to the EX as MESH sattellites. They are ONLY extenders so no they don't entegrate like actual RBS. They CAN work in cases were additional wifi is needed in a pinch and when RBS supplies are out of stock or can't be found. They don't need to integrate as well. Just provide additional wifi coverage for those situations. They work fine with Orbi systems.
