somewhat
Sep 20, 2017Tutor
Satellite - network link down multiple times per day
I have my Windows laptop connected directly via ethernet to my satelitte, however I've been noticing multiple link down issues each day since I cabled directly rather than rely on wireless: Intel...
somewhat
Sep 22, 2017Tutor
Hi Darren,
Thanks for the reply. I was running Router Firmware Version V1.12.0.18 and wasn't aware of the 2.0 release thanks - I've manually updated and will monitor it for the link drops.
Re "mumimo and beamforming" - these aren't enabled (default from memory) but note my issue is to do with Wired connections to my sattelite intermittently disconnecting so not sure this would be related??
Cheers
madbrain
Sep 23, 2017Luminary
I think I am running into the same problem with my printer, wired directly to the back of a satellite :
I'm on the 2.0.0.74 firmware already, though.
- somewhatSep 24, 2017Tutor
Interesting, thanks! I upgraded to V2.0.0.74 and unfortunatley no change, see screenshot - still dropping multiple times a day.
Surely can't be a common firmware issue, perhaps we have bad satellites?
- DarrenMSep 25, 2017Sr. NETGEAR Moderator
If you are still having disconnect issues after the 2.0 update and a factory reset send me a PM with your name, email, and phone number.
DarrenM
