GremDaddy
Oct 07, 2017Aspirant
Satellite blinking white will not reset
Hi, My 2nd satellite worked for a few days, but now it constantly blinks white. The router and 1st satellite are fine. My overall WiFi is great. Only the satellite is malfunctioning. I have held do...
aaz
Oct 07, 2017Virtuoso
Pulsing white. Your Orbi router and satellite are applying a configuration or updating their firmware.
Since that is unlikely for so long of a time, and if you cannot reset it there is a chance that it is bricked. Did the power possibly go out on it while it was applying firmware?
GremDaddy
Oct 08, 2017Aspirant
Thanks's for your response. It's unlikely that it lost power during a firmware update, but I guess it's possible. I have not had the satellite very long so I will try to get it swapped out.
Thanks again!
- aazDec 12, 2017Virtuoso
Ha Ha, now having this issue myself after having done a config restore.
Showing one satellite connected - but I can see the other one on the network if I go to its IP.
This is just crazy that this is happening after my support period of 90 days is done and now I have no recourse except to troubleshoot this myself. This is just crazy.
