GremDaddy
Oct 07, 2017Aspirant
Satellite blinking white will not reset
Hi, My 2nd satellite worked for a few days, but now it constantly blinks white. The router and 1st satellite are fine. My overall WiFi is great. Only the satellite is malfunctioning. I have held do...
jquest2
Mar 03, 2018Aspirant
Hmm. Any updates? I just bought this system today and I hooked up one satellite and router. Then I went a upgraded the firmware. Everyone worked fine. I then decided to add the 2nd satellite, however, all it does is just blink white. Did I mess it up by only configuring 1 satellite rather than both at setup? Help.
Mar 03, 2018Guru - Experienced User
How big is your house?
A factory reset on the 2nd Satellite should kick it into reboot mode with default settings and the LED should start to blink white. If it doesn't, then this Satellite could be faulty.
- jquest2Mar 03, 2018Aspirant
My house is about 3500 square feet but the walls are solid concrete. Now I see the power light blinking red :(
- FURRYe38Mar 03, 2018Guru - Experienced User
You could test the other Satellites Power supply with the 2nd one to see if it could be a power supply issue.
I would ask for an RMA for the 2nd unit.
I appreciate the assistance. If I can't figutre it out in the next 15 min, I'm taking this back to Costco and exchanging it. Just bought the dag gone thing today :/
