GremDaddy
Oct 07, 2017Aspirant
Satellite blinking white will not reset
Hi, My 2nd satellite worked for a few days, but now it constantly blinks white. The router and 1st satellite are fine. My overall WiFi is great. Only the satellite is malfunctioning. I have held do...
jquest2
Mar 03, 2018Aspirant
My house is about 3500 square feet but the walls are solid concrete. Now I see the power light blinking red :(
Mar 03, 2018Guru - Experienced User
You could test the other Satellites Power supply with the 2nd one to see if it could be a power supply issue.
I would ask for an RMA for the 2nd unit.
- jquest2Mar 03, 2018Aspirant
I appreciate the assistance. If I can't figutre it out in the next 15 min, I'm taking this back to Costco and exchanging it. Just bought the dag gone thing today :/
Great, now the light is steady green with the same power adapter. But still blinking white. I'm heading off to dinner so I've give it 15 minutes when I get back.
- FURRYe38Mar 03, 2018Guru - Experienced User
Hope the new one works if you get it.
Good Luck.
jquest2wrote:I appreciate the assistance. If I can't figutre it out in the next 15 min, I'm taking this back to Costco and exchanging it. Just bought the dag gone thing today :/
- GremDaddyMar 03, 2018AspirantI tried all sorts of ways to get mine to reset. Eventually I came to the conclusion that mine was a brick so I exchanged it for another. My system has worked great since then. You are on the right track to just return/exchange the unit.
