billyest
Sep 17, 2017Aspirant
Satellite blue light stays on with my RBS50 orbi wifi setup
when I first set-up my orbi wifi, the satellite showed blue, proving a good connection, and then the blue light went off. now, several months later, the blue light is on and won't go off at all. ever...
steveamb
Nov 19, 2017Aspirant
Any feedback on this? I'm having the same issue. All is working fine but the blue light on the satellite is always on.
- billyestNov 19, 2017Aspirant
hello there... yes someone did respond to my question, and suggested i simply unplug the satellite for a few minutes and plug it back in... it works! i feared i'd have to start all over but somehow it all re-connected to the home base automatically. the blue light went back on, then off, and has been off since. good luck!
