mickiii
Aug 01, 2017Tutor
Satellite connected to 2.4 Ghz, not 5 Ghz?
Just set my system up, updated to latest firmware, but now downgraded to see if that solved anything. Currently I am on 1.11.0.20. When connecting to the satellite, I get the picture below showing 2...
namirkhan
Aug 20, 2017Aspirant
Where did that screenshot come from?
- Mgomez85Aug 20, 2017ApprenticeType the IP address for your sat you, you can find the ip from your main router dhcp list, it will ask you for user name and password, use the same login info for your router you will be greeted with a that page, not much info on the sat unit btw but I wish we had a option to restart the sat unit from that page! đ©đ
- namirkhanAug 21, 2017Aspirant
Got it! Thanks!
