mickiii
Aug 01, 2017Tutor
Satellite connected to 2.4 Ghz, not 5 Ghz?
Just set my system up, updated to latest firmware, but now downgraded to see if that solved anything. Currently I am on 1.11.0.20. When connecting to the satellite, I get the picture below showing 2...
gideon99
Sep 15, 2017Tutor
My satellite keeps dropping down to 2.4 Ghz too. I have gone as far as sticking a pin in the reset button hole to see if a hard reset would help it. I'm thoroughly confused because I thought the wireless backhaul would always be on the dedicated 5 Ghz band. Here's a screenshot from my router (installed latest FW V2.0.0.54):
Can someone from Netgear please explain what is going on here? If I disconnect the power, via plug or power button, it does go back to 5 Ghz but it seems to always drop down to 2.4 Ghz.
mczerwon
Sep 18, 2017Aspirant
Hi All, I´ve exact the same problem here:
Hardwareversion: RBW30
Firmwareversion: V2.0.0.34_1.0.21
I´m also interessted to know what is going on here.
