Tbsteph
Aug 01, 2018Star
Satellite Connection at 2.4
According to the orbil log on screen my one satellite is connected on the 2.4G channel. Why?
FWIW, I have owned the Orbi RBR50 for over a year (Running 2.1.4.16). Never saw this with any previ...
Aug 01, 2018Guru - Experienced User
Satellites connect to both 2.4G and 5G radios...
Is the satellite working?
- TbstephAug 01, 2018Star
Yes. But isn't the 2.4 speed less than 5G? FWIW, this is not an issue with the satellite distance from the main unit. The 2.4G connection occurs even when the satellite is right next to the router.
- FURRYe38Aug 01, 2018Guru - Experienced User
Yes. However the 2.4Ghz needs to be connected as well to provide 2.4ghz wifi to those devices that don't support 5Ghz wifi.
But, I thought the backhaul channel from the router to satellite was only 5G. How can the satellite broadcast a 5G signal if it is only receiving a 2.4G signal from the router? If I sound confused, it's because I am. I do appreciate your input.
