sdunnin68
Sep 23, 2016Aspirant
Satellite Connection Status
Is there a way to determine what the connection status is between router and satellite? Devices are showing as attached to the Satellite on the Attached Devices page. Not really sure if I can tell if...
th3w01f
Sep 24, 2016Apprentice
If you watch the satellite for about a minute after reconnecting you should see the final color. It's kind of a pain and I don't know how accurate it is. Mine was blue, when I finally caught it.
After that you can go under Advanced -> Advanced Home -> Internet Port -> Show Statistics. At the bottom you'll see Internet Backhaul. Mine shows 1733 and moving it a bit hasn't changed it so again, I'm not sure how accurate it is. The Rx and TX Bytes don't look correct for any of my radios. After 20 hours I’m showing 7 total for b/g/b, 159 total for a/n/ac and 124 million for backhaul.
sdunnin68
Sep 24, 2016Aspirant
I definately see Tx and Rx counts incrementing for the Backhaul so that must mean they are working. Connections with Satellite are strong and have good speed. Router still pulsing magenta so I don't know what that means though.
