sdunnin68
Sep 23, 2016Aspirant
Satellite Connection Status
Is there a way to determine what the connection status is between router and satellite? Devices are showing as attached to the Satellite on the Attached Devices page. Not really sure if I can tell if...
sdunnin68
Sep 24, 2016Aspirant
I definately see Tx and Rx counts incrementing for the Backhaul so that must mean they are working. Connections with Satellite are strong and have good speed. Router still pulsing magenta so I don't know what that means though.
th3w01f
Sep 24, 2016Apprentice
@loomis1975, I think you're 100% correct that those are just labels, so there doesn't appear to be a way to see the quality of the backhaul connection. Support said there was so hopefully I'm just missing it or it's coming in a new FW.
@sdunnin68, I can't find anything on that status either, and I never saw that behavior.
From the main manual - Orbi Full Manual
