sdunnin68
Sep 23, 2016Aspirant
Satellite Connection Status
Is there a way to determine what the connection status is between router and satellite? Devices are showing as attached to the Satellite on the Attached Devices page. Not really sure if I can tell if...
Socalgas
Sep 29, 2016Aspirant
I having similar problems with the satellite. It blinks amber then turns solid blue. I looked in my devices connection but it only shows my router and other devices. Except for my satellite.I live at 1500 sq ft townhouse which is three floors. Router located on first floor and sarellite on third. What's the deal?
- DarrenMSep 30, 2016Sr. NETGEAR Moderator
Hello socalgas
Have you tried to move the Satellite to the second floor and see if it will connect?
DarrenM
