msfox99
Oct 30, 2019Guide
Satellite connection status
Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the s...
- Oct 30, 2019
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
Oct 30, 2019Guru - Experienced User
Did you power OFF the RBR and RBS as well?
- msfox99Oct 30, 2019Guide
They are around 30-40 feet. Everything has worked fine for the last year plus. I did power cycle everything.
I haven't done a factory reset yet, and would prefer to avoid that for now.
- FURRYe38Oct 30, 2019Guru - Experienced User
I think I will go ahead and do a factory reset tomorrow. I assume that I only need to reset the router, not the satellites?
Thanks for your help.
