msfox99
Oct 30, 2019Guide
Satellite connection status
Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the s...
- Oct 30, 2019
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
Oct 30, 2019Guru - Experienced User
msfox99
Oct 30, 2019Guide
I think I will go ahead and do a factory reset tomorrow. I assume that I only need to reset the router, not the satellites?
Thanks for your help.
- FURRYe38Oct 30, 2019Guru - Experienced User
Ok.
- FURRYe38Oct 31, 2019Guru - Experienced User
Let us know if a factory reset and setup from scratch helps your system. I manually loaded v38 FW and factory reset and setup from scratch. No issues with satellite connections, wired or wireless.
msfox99 wrote:I think I will go ahead and do a factory reset tomorrow. I assume that I only need to reset the router, not the satellites?
- msfox99Oct 31, 2019Guide
Yes, after I did a factory reset and re-set up the router, everything seems to working fine. Both satellites are now listed as well as all other attached devices.
Thanks again for your help.
Good to hear. Glad it's working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
