msfox99
Oct 30, 2019Guide
Satellite connection status
Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the s...
- Oct 30, 2019
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
Retired_Member
Oct 31, 2019
msfox99 wrote:Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the satellites as being connects. That is, it says, 0 satellites. But when I power down and up a satellite, it shows the blue light when done starting up, indcating a good backhaul connection. And the devices near the satellites seem to have a very strong signal. The satellites used to show as being active always. I have gone through the sync process.
The current firmware on the base router is V2.5.0.38.
There's your problem: V2.5.0.38.
How did you come upon this?
Any ideas! Thanks.
- msfox99Oct 31, 2019Guide
That is the current latest version. I clicked Update Firmware on the web interface, and it did the update. What are you saying VAJim?
- Retired_MemberOct 31, 2019
msfox99 wrote:That is the current latest version. I clicked Update Firmware on the web interface, and it did the update. What are you saying VAJim?
IF your system was working fine before the update....why update?
