msfox99
Oct 30, 2019Guide
Satellite connection status
Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the s...
- Oct 30, 2019
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
msfox99
Oct 31, 2019Guide
That is the current latest version. I clicked Update Firmware on the web interface, and it did the update. What are you saying VAJim?
Retired_Member
Oct 31, 2019
msfox99 wrote:That is the current latest version. I clicked Update Firmware on the web interface, and it did the update. What are you saying VAJim?
IF your system was working fine before the update....why update?
