msfox99
Oct 30, 2019Guide
Satellite connection status
Hi. I have had the RBK50 for a while, and also have a 2nd satellite. (RBS40) Recently, around the time I updated to the latest firmware, neither the web admin page, nor the Android app, show the s...
- Oct 30, 2019
Try a Generate backhaul password for the RBS under Advanced/Advanced settings/Wireless settings. See if this helps. If not, A reset will be needed on the RBR and RBS setup from scratch.
msfox99
Oct 30, 2019Guide
I think I will go ahead and do a factory reset tomorrow. I assume that I only need to reset the router, not the satellites?
Thanks for your help.
Oct 31, 2019Guru - Experienced User
Let us know if a factory reset and setup from scratch helps your system. I manually loaded v38 FW and factory reset and setup from scratch. No issues with satellite connections, wired or wireless.
msfox99 wrote:I think I will go ahead and do a factory reset tomorrow. I assume that I only need to reset the router, not the satellites?
- msfox99Oct 31, 2019Guide
Yes, after I did a factory reset and re-set up the router, everything seems to working fine. Both satellites are now listed as well as all other attached devices.
Thanks again for your help.
- FURRYe38Oct 31, 2019Guru - Experienced User
Good to hear. Glad it's working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
