chickenlegs99
Nov 01, 2019Guide
Satellite disconnecting
Hello Orbi experts I have an almost new Orbi RBR50 and satellite set up at home. Problem: My Orbi satellite drops connection to the Orbi router intermittently. This has only recently started (th...
- Nov 06, 2019
VAJim, I don't think it is the firmware in this case. I installed v2.3.5.30, replacing the newer version that you site as problematic and the issue of the satellite disconnecting, reconnecting or just being static in a sort of limbo happened with v2.3.5.30 which I understand from others is more stable.
Retired_Member
Nov 01, 2019For starters I would do a search here on V2.5.0.38
Lots of complaints
How did you get the firmware version?
- chickenlegs99Nov 01, 2019GuideThank you for responding. I updated the firmware through the Orbi app I think.
