chickenlegs99
Nov 01, 2019Guide
Satellite disconnecting
Hello Orbi experts I have an almost new Orbi RBR50 and satellite set up at home. Problem: My Orbi satellite drops connection to the Orbi router intermittently. This has only recently started (th...
- Nov 06, 2019
VAJim, I don't think it is the firmware in this case. I installed v2.3.5.30, replacing the newer version that you site as problematic and the issue of the satellite disconnecting, reconnecting or just being static in a sort of limbo happened with v2.3.5.30 which I understand from others is more stable.
JOHNMMALONEY138
Nov 02, 2019Aspirant
UNABLE TO LOG INTO TO MY ORBI WITH USER NAME : ADMIN AND DEFAULT PASSWORD FROM ORBI ROUTER. ANY HELP
TRIED FORGOT PASSWORD BUT SCREEN GOES BACK TO ORIGINAL LOG IN . CAN'T MANAGE ORBI SETTINGS.
Gregron
Nov 02, 2019Star
Uh this isn’t the thread for that and I don’t know why you are typing in all caps but I am pretty sure if you factory reset the Orbi by putting a paper clip in the reset button hole in the back it will reset it to fresh out of the box status to set it up again.
https://m.youtube.com/watch?v=cMw4ePACgc4
