chickenlegs99
Nov 01, 2019Guide
Satellite disconnecting
Hello Orbi experts I have an almost new Orbi RBR50 and satellite set up at home. Problem: My Orbi satellite drops connection to the Orbi router intermittently. This has only recently started (th...
- Nov 06, 2019
VAJim, I don't think it is the firmware in this case. I installed v2.3.5.30, replacing the newer version that you site as problematic and the issue of the satellite disconnecting, reconnecting or just being static in a sort of limbo happened with v2.3.5.30 which I understand from others is more stable.
Retired_Member
Nov 06, 2019
FURRYe38 wrote:Thanks for letting us know. Ya, 1400sq ft home only needs 1 wifi source. Having two would cause problems.
It's the firmware. What problem might be caused by having a Sat in a 1400 sq foot home?
Remember this....Problem: My Orbi satellite drops connection to the Orbi router intermittently. This has only recently started (there hasn't been any new wifi connected items since installing Orbi).
chickenlegs99
Nov 06, 2019Guide
- Retired_MemberNov 06, 2019
chickenlegs99 wrote:VAJim, I don't think it is the firmware in this case. I installed v2.3.5.30, replacing the newer version that you site as problematic and the issue of the satellite disconnecting, reconnecting or just being static in a sort of limbo happened with v2.3.5.30 which I understand from others is more stable.
If the Orbi has been running fine and you made no changes, then there was a firmware update....? You tell me.
Now that you have v2.3.5.30, you may need (if you haven't already) reboot ALL. Give it a few days.
