Orbibot
Nov 10, 2017Aspirant
Satellite firmware and constant blue light
My orbi satellite has suddenly kept the constant blue light on, unable to update the firmware, any suggestions?
DarrenM
Nov 13, 2017Sr. NETGEAR Moderator
Are you able to log directly into the satellite using its local ip address? and then your can try a manual update of the firmware.
DarrenM
- OrbibotNov 13, 2017AspirantI have tried to do the manual update and it either says failed or service unavailable.
When trying to log in to the satellite it just keeps sending me to the log in page, can’t get beyond it.- DarrenMNov 13, 2017Sr. NETGEAR Moderator
Have you tried to factory reset that satellite by holding the reset button for 10+ seconds?
DarrenM
- OrbibotNov 13, 2017AspirantI have reset it, now it keeps going to the magenta color and my router keeps going off and online, the “check for updates” feature won’t complete on the app now. Went back to the orbilogin site and now there are no updates available even the manual way...
