CrimpOn
May 22, 2017Guru - Experienced User
Satellite Hangs on "Show Attached Devices"
I'm one of the people who wants to know whether devices are connected to the Orbi or to the Satellite. On the previous firmware, the Attached Devices list was thoughtfully divided into Router and Sa...
Streak2
May 23, 2017Master
Try logging in using a different browser.
Both 1.9 and 1.10 show the same attached devices screen for me.
Looks like there could be some naming inconsistencies between the router and satellite web GUI's.
JMU1998
May 23, 2017Luminary
ISSUE exists if you rename a device on the list on the Main Orbi unit then log onto the Satellite the request to list devices hangs forever. You have to reboot the Satellite for the listing on the satellite to be displayed again...annoying not the refinement you expect from a $400 system.
- CrimpOnMay 23, 2017Guru - Experienced User
Since the Satellite does not have the capability to give devices a name, EVERY time a device is given a name on the Router, the Satellite has to be rebooted?
i.e. It doesn't matter if the device is currently attached to the Router or the Satellite? (Or, if the device is currently attached at all?)
I had tried four browsers, and all did exactly the same thing.
THANKS!!!
- Streak2May 23, 2017Master
MIne brings up the connected devices screen OK and it does show any currently connected devices.
If I hit the refresh button I get "please wait a moment".
I just tested this with both my phone and tablet.
