nickolausj
Aug 13, 2020Aspirant
Satellite internet drops out or slows randomly
I am currently on 2.4.1.16 and have a router w/ single sat system. Now I am having an issue with the satilite randomly dropping connectivity to devices to almost no bandwidth. ...
nickolausj
Aug 15, 2020Aspirant
Yes, I recently factory reset it and I disabled UPnP, Daisy Chaining. I enabled beamforming. It's still dropping out. I have a lot of HUE lights, and sonos speakers, and nest security/cameras.
It is still dropping out randomly.
Aug 15, 2020Guru - Experienced User
If you turn off the RBS, leaving the RBR online, does the devices maintain connections with the RBR?
Possible your RBS maybe faulty...
- nickolausjAug 15, 2020Aspirant
I have turned off my RBS and devices attached to the satelite have been dropped from the network.
- FURRYe38Aug 16, 2020Guru - Experienced User
Sounds like a faulty RBS.
Try this, manually reload FW on to the RBS using a wired PC directly to the RBS web page. Then factory reset the RBS and re-add it to the RBR.
If it still fails, the RBS will need to be replaced.
