Jeffgear
Aug 21, 2024Virtuoso
Satellite IP addresses
I noticed in the device table in the web UI that the IP addresses that have been automatically assigned to my three RBS50 satellites connected via WiFi bak haul are all 192.168.1.250 which seems odd ...
Aug 21, 2024Guru - Experienced User
What FW is loaded on the system?
- JeffgearAug 21, 2024VirtuosoFirmware 2.7.5.4 for all except for the outdoor that is 2.7.4.12 and I’ve rebooted them all a few times.
I went into the DHCP config and added one of the .250 as a reserved IP then added each other the others as .249 and .248 which sort of worked - but with two adamant to remain as .250. A reboot at that point now has them on unique IPs from .247.
What is odd is why they all happily coexisted as duplicates - is this a feature of wireless backhaul or just a UI reporting quirk?- FURRYe38Aug 22, 2024Guru - Experienced User
Looks like bad behavior...or in a bad state...
- JeffgearAug 29, 2024Virtuoso
Yes I've done a few rebuilds and only noticed this recently. I manually re assigned IPs so they are now unique.
