gimimr
May 02, 2020Aspirant
Satellite is not showing up on orbilogin or orbi app even though it is connected (blue light)
I managed to sync my moden/router orbi CBR40 with my new RBS40V ORBI voice add-on. I seem to have a strong wifi signal near the satellite (on the opposite end of the home), and the satellite did have...
CrimpOn
May 02, 2020Guru - Experienced User
Orbi Voice is unique enough that there is a community forum devoted entirely to it:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
You might get a more informed response by also posting in that forum. (Although this seems too basic a situation to involve the "special" Orbi Voice features.)
So, the Orbi voice does not appear anywhere on the Attached Devices screen? Not even as a "regular device"?
In regard to the strong WiFi signal from the Orbi Voice, can a device connect to it and access the internet?
- gimimrMay 02, 2020Aspirant
I already had a RB40V modem in my house, but I wanted to add a satellite so I bought a RBS40V. I went to the process of synchronizing them by the rear sync bottons, The process looked OK because I got a still blue light on the satelite at the end of the process. Then when I try to ask something to alexa, it says that " IT LOOKS THAT THE DEVICE IS NOT REGISTERED AND THAT I HAVE TO DOWNLOAD THE NETGEAR NIGHTHAWK APP and follow the instruccions." so I went and installed it, followed the instrucions to add a satellite on a mesh systems, but at the end it says that the "APP DOES NOT SUPPORT YOU ROUTER" so I went to the ORBIAPP, add a satellite and follow the instruccions and it says that no satellite is found, it does not show up on my network map. I ckecked the firmware on the router settings. it is v2.3.512.
I do not what else to do. The next step is to return it
thak you
- CrimpOnMay 02, 2020Guru - Experienced User
Before giving up, you might try posting in the communit forum specifically devoted to the "voice" product:
Since the question pertains to the "Alexa" feature, people who watch that forum are more likely to have relevant experience.
