Paella
Aug 17, 2020Aspirant
Satellite is slow
Hi I have an RBR50 and RBS50 The router works fine and get fast upload/download for the service I paid for. the satelite howerver has always been slow. from the router i get ~270Mbps down and ...
- Aug 17, 2020
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
