jonmell's avatar
jonmell
Guide
Aug 25, 2021
Satellite issue on Orbi 6
Hi - I have an Orbi 6 RBR850 and two RBS850 satellites.   All working fine for a year or so then had to do a factory reset of the entire system to fix a password issue.   Now one satellite is wor...
  • FURRYe38's avatar
    Aug 25, 2021
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
