MikeandKelly
May 01, 2020Follower
satellite issue RBs10
When i attmpt to connect to my satellites it will not accept my password. It says incorrect password. I can connect directly to the router just fine. Do the satellites have their own password?
1 Reply
Possible that the RBS didn't sync correctly with the RBR. I would run thru re-syncing the RBS to the RBR. You may need to factory reset the RBS then re-sync the RBS. If nothing resolve this, you may need to contact NG support to get help on this.
