djc6
Nov 22, 2017Luminary
Satellite Issues since Orbi 2.0 upgrade
I purchased an RBK53 from Costco over a year ago, in early November 2016. It had been problem free up until I believe the Orbi 2.0 update. The first thing I noticed was all of a sudden in the mi...
st_shaw
Nov 22, 2017Master
Move the units so the satellites are closer to the router. The 2.0 FW requires a closer proximity for stable connection.
- RobBassNov 23, 2017Guide
Ughh these are not good answers why is 2.0 bug riddled... and why is Netgear ignoring tons of posts about how bad 2.x is
- st_shawNov 23, 2017Master
There is nothing written about bugs in this thread. 2.0 is not bug riddled. Orbi is wireless and wireless signals can vary from hour-to-hour. It is the user's responsibility to place the units in a location where they can obtain a stable wireless signal.
I don't believe an update should cause things to have to be physicaly moved... and even if this is the case, is it captured somehere? I don't buy it, I have had incredibly slow wifi issus with 2.x which 1.x mostly solved, all things equal.
