djc6
Nov 22, 2017Luminary
Satellite Issues since Orbi 2.0 upgrade
I purchased an RBK53 from Costco over a year ago, in early November 2016. It had been problem free up until I believe the Orbi 2.0 update. The first thing I noticed was all of a sudden in the mi...
RobBass
Nov 23, 2017Guide
Ughh these are not good answers why is 2.0 bug riddled... and why is Netgear ignoring tons of posts about how bad 2.x is
st_shaw
Nov 23, 2017Master
There is nothing written about bugs in this thread. 2.0 is not bug riddled. Orbi is wireless and wireless signals can vary from hour-to-hour. It is the user's responsibility to place the units in a location where they can obtain a stable wireless signal.
- RobBassNov 23, 2017Guide
I don't believe an update should cause things to have to be physicaly moved... and even if this is the case, is it captured somehere? I don't buy it, I have had incredibly slow wifi issus with 2.x which 1.x mostly solved, all things equal.
- st_shawNov 23, 2017Master
The 2.0 firmware reduced the range between the satellites and router compared to the older firmware revisions.
You should ignore the old firmware. It's old and you cannot use it because Orbi will auto-update.
If you want to get your Orbi to work, you should start with your Orbi units closer together and establish that everything is working properly first. You also need to make sure the rest of your network is confgured properly:
- Make sure you have only one router on the network. If you put Orbi behind another router you need to run Orbi in access point mode.
- Make sure you turn off WiFi on your old modem or router, if you still have one in service.
- Get rid of any old WiFi extenders or other wireless access points.
- Don't put any other wireless devices (Sonos, wireless speakers, Hue bridges, phones, Bluetooth, etc.) close to the Orbi units.
- Run a WiFi scanning application and look for neighboring access points that might interfere with Orbi.
Once you have established that your network is configured and working properly, you can experiment with moving the Orbi units farther apart. The maximum separtion might be 25 to 50 feet, depending on the construction in your house. Understand that if you move the Orbi router and satellite too far apart, or have too many walls between, you will have intermittent issues.
I wasted most of my evening troubleshooting with the new 2.X firmware, today wifi speeds are in the 260-310 range and not 20-100 like yesterday, so I am very hesistant to upgrade the firmware. The firmware has some issues just do a Google search the results will speak for themselves, one simple example is the QoS page does not work, it prompts you to do a speedtest over and over and does not show you any options once the speedtest has finished. I will give it one more shot this weekend and if the issues return with 2.x, I will return it, I hate when I have to constantly tinker with a product to get it to work.
My house is not that big, and the router and sat. are most defintely with 20 feet or so, its an open floorplan so no many walls besides the 1st story cieling.
I think I had my expectations too high given the rave reviews but I guess when it comes to WiFi YMMV.
