Fitzcal
Jun 25, 2017Tutor
Satellite Keeps losing connection
Orbi worked great the first week. Since then it drops connectivity daily along with the satellite.
everich
Jun 27, 2017Tutor
My local netgear branch(S.Korea) provided a beta firmware for this problem. - V1.12.0.14
My Orbi works great over 32h+ so far.
Seems newer firmware will help.
ArtLee
Jun 27, 2017Apprentice
I have had to move my satellite twice because it keeps disconnecting the backhaul, I guess. If this current spot fails, I'll return the Orbi kit, You must admit, though, that 32 hours isn't long.
- Doug-48051Jun 27, 2017Luminary
From what I read.... the back haul is initiated by the router... so i moved the router to the center of the house.... and the sat to the further point. But only way I could do this is the 2 network jacks build into my house.
But, you are correct, if it doesnt suit my needs I will send it back also.
Doug G
FW version: RBR50 / RBS50 Firmware Version 1.11.0.20
OS: Windows 10 Creative
ISP Comcast at 150mbps
14 connected devices.
2,200 sq ft ranch open floor plan.
Router and Sat. about 45 ft a part. (two walsl)
