Fitzcal
Jun 25, 2017Tutor
Satellite Keeps losing connection
Orbi worked great the first week. Since then it drops connectivity daily along with the satellite.
ArtLee
Jun 27, 2017Apprentice
I have had to move my satellite twice because it keeps disconnecting the backhaul, I guess. If this current spot fails, I'll return the Orbi kit, You must admit, though, that 32 hours isn't long.
Doug-48051
Jun 27, 2017Luminary
From what I read.... the back haul is initiated by the router... so i moved the router to the center of the house.... and the sat to the further point. But only way I could do this is the 2 network jacks build into my house.
But, you are correct, if it doesnt suit my needs I will send it back also.
Doug G
FW version: RBR50 / RBS50 Firmware Version 1.11.0.20
OS: Windows 10 Creative
ISP Comcast at 150mbps
14 connected devices.
2,200 sq ft ranch open floor plan.
Router and Sat. about 45 ft a part. (two walsl)
