dkaplin
Jul 15, 2018Aspirant
Satellite keeps reconnecting to the router instead of daisy chaining
My most remote satellite keeps disconnecting from its nearest satellite (when it shows great performance) to the router (when the performance sucks). I keep moving the satellites around but no joy fr...
dkaplin
Jul 19, 2018Aspirant
thanks for the reply. House is about 3800 sq ft. I haven't measured distances, but the router is on the first floor at one end of the house. First satellite is in the room above it, offset towards the other end of the house by about 15 feet. The second satellite is at the other end of the house on the second floor and swings between connecting to the first satellite and the router. It performs MUCH better when daisy chained, so won't turn that off. When the second satellite connects to the router, client connections drop and music drops out etc.
Don't know why I'd mess with 2.4; the issue is the backhaul connection.
Wifi signals on 3 sides of course
Jul 20, 2018Guru - Experienced User
Your placement of the 1st satellite is not good. Starting placement should be around 30 feet from the router. The router can cover up to around 30 feet by itself. So maybe one reason why the Daisy Chain isn't working effectively.
- dkaplinJul 28, 2018Aspirant
Well that worked for only about 5 minutes. I moved Satellite 1 farther away - probably about 35 feet. then I rebooted Satellite 2 - it connected to Satellite 1 briefly, then swung itself over the the primary router. This means poorer performance for anyone connected to Satellite 2, and its connection to the router swings from good to poor. When it is poor it tends to stay locked onto the router.
Other thoughts? Are there any settings that can affect this?
- loomis1975Jul 29, 2018LuminaryThere is an aggressive roaming setting in /debug.htm on each of the satellites. I am not sure if it will help with backhaul daisy chain roaming issues.
It would be nice if we could lock in preferred daisy chain partners.
