dkaplin
Jul 15, 2018Aspirant
Satellite keeps reconnecting to the router instead of daisy chaining
My most remote satellite keeps disconnecting from its nearest satellite (when it shows great performance) to the router (when the performance sucks). I keep moving the satellites around but no joy fr...
Jul 29, 2018Guru - Experienced User
Since you home is only about 3800 sq ft, I would disable one of the satllites. The base router and just 1 satellite should be able to handle coverage of your home. I use only 1 satellite with my router and I have a 5000sq ft home. Try it and see.
- dkaplinJul 29, 2018Aspirant
and it does OK for most of the house with 2. The third router is all about getting a signal out onto my deck. Two doesn't cut it for that.
