blakejnd
Aug 13, 2018Aspirant
Satellite lights turning on constantly
I find that the satellite lights (on top) are constantly on. The good news is that most of the time, it is blue, but this is happening often.
It can be especially annoying at night. And yes, ...
Aug 13, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
It can be especially annoying at night. And yes, it does flash amber occasionally.
I will normally re-sync or reboot. I just did not know if this was an issue.
Thoughts? Thanks!
blakejnd
FW is V2.1.4.6_1.0.8
The modem is the new Orbi w/ modem.
Home is only about 1000 sq ft with the satellite about 30 feet away maybe at most.
I am using Auto. So you are saying set up the satellite on its own channel right?
Sorry if I sound dumb, but I am not super sophisticated when it comes to routers and modems...
- vkdeltaAug 13, 2018NETGEAR Employee Retired
Please post a screenshot of ATTACHED devices here. Is your satellite connection on 5GHz? Is it shown as "GOOD" ?
