jithin
Oct 03, 2018Tutor
Satellite looses connection and has to restart router to fix
What I have observed is that the router still has internet and if I move to a room where router is the closest one, I get internet, but the room with Satelite does not have Internet. Restarting rout...
Oct 08, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
