mbski
Oct 28, 2016Guide
Satellite looses connection to base
Roughly every few days I notice my satellite with solid magenta color. This has been happening since new. (pre-ordered) I have moved it around to different locations 6 times, with same results. I hav...
- Jan 05, 2017
Hello everyone
We have release a new firmware version 1.4.0.34 you may want to try and upgrade and see if this resolves the issue.
DarrenM
aruit
Jan 17, 2017Guide
Hello Darren,
My Netgear Orbi is now running without the solid Magenta light problem, so this problem is really solved with firmware 1.4.0.34.
Thank you for the support,
Anton
aruit
Feb 05, 2017Guide
I was only looking at the Satellite, because that was my problem, and the light of the Satellite did not burn Magenta for several week.
But I was looking at the Router and I found the light of the Router burning Magenta.
In Netgear Genie I could not find the IP address of the Router, but I found the IP Address of the Satellite and I could ping to the Satellite.
With Wifi Analyzer I saw that both the Router and the Satellite where sending wifi signal and by walking from Router to the Satellite it was switching from signal.
The wifi of both are working, but still the Router is burning Magenta.
So the firmware update solved the Satellite to burning solid Magenta, but did not solve the Router to burning solid Magenta.
