bisu-fan
Oct 31, 2018Aspirant
Satellite Non-stop Disconnecting During Gaming
This has been an issue on and off for a few months (upgrading the firmware helped alleviate the issue when it was most prevalent this summer), but this past month, my second satellite will disconnect...
ekhalil
Oct 31, 2018Master
This software seems to have issues with some wired devices. If you have any mesh speakers (e.g. Sonos) wired to Orbi, please test to disconnect them and see if you will see improvements.
Wired Sonos seem to cause IP loops over time which will degrade the system performance and will consequently cause different "strange" issues.
clammerds
Oct 31, 2018Apprentice
Are you saying that we'll get less issues and it works better if Sonos connects wirelessly to the Orbi rather than either a) wired or b) Sonos Boost (which is how mine are currently connected)?
Thanks in advance for your reply,
- ekhalilOct 31, 2018Master
clammerds Yes, according to my experience, I'm having a better and much more stable Orbi system when I disconnected all my wired speakers and connected them wirelessly instead.
- clammerdsNov 01, 2018Apprentice
Thanks ekhalil for the clarification.
I'll change mine to Wifi and see if it improves stability.
Let's hope that they release a firmware soon that allows everything to play nicely. I feel slightly miffed that I've paid a premium price for a product that has so many issues.
- FURRYe38Nov 01, 2018Guru - Experienced User
Youll need to contact the Mfrs of your speakers for updates and additional information on issues with connections with there product. It's not NG duty to correct other device Mfrs issues. This is not the first time there have been issues with SONOs causing problems on Orbi's and other Mfr wifi routers.
