Paulk2078
Jan 30, 2021Aspirant
satellite not sinking
I have installed the system however the satellite will not connect despite being next to it, any ideas please. I have rebooted the system and disconnected etc.
Paulk2078
Jan 31, 2021Aspirant
How would I make sure they are all on the same system if I can’t get them to sink.
Thanks
Thanks
Jan 31, 2021Guru - Experienced User
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR
- Paulk2078Jan 31, 2021AspirantWill the router need to be connected to the internet or just powered up ?
Thank you
