packling's avatar
packling
Satellite not working every 5 mins
Hi,   I have just bought a RBK 50 router and satellite and both upgraded to firmware V2.2.1.210.  My satellite seems having problem and our device can't find the wifi signal every a few minutes. ...
  • ekhalil's avatar
    ekhalil
    Mar 07, 2019
    1. The SW 2.2.1.210 has issues with Ethernet Backhaul and handling of wired devices in general. Please disable Daisy Chain if you stay on 2.2.1.210 since there is an issue when you have Ethernet Backhaul and enable Daisy Chain at the same time.
    2. It's also recommended to go for the latest 2.3.0.32 where quite few wired LAN issues are solved.
    3. What other devices do you have attached to your network? What wired devices do you have connected to your Router and Satellite?
