abcchana
Nov 02, 2019Aspirant
Satellite office RBR50
Hi all, my satellite of RBR50 is sometimes offline / discount but the main one (mother) is still online. I have diabled any power saver setting. And the discount happens with no pattern Is it du...
Nov 03, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
I
Is it due to the hardware problem? I still get warrant. Could I know it is possible to exchange the new satellite? and now is the process? Coz my call/help service were already expired.
Many thanks
abcchana
Nov 03, 2019Aspirant
Hi Furrye38,
Thank you for your detailed comments.
Could I ask below?
1.Try enabling Beamforming and MIMO(MIMO may or maynot be needed)
How to do?
2, how to manually set and fix the channel with Orbi?
Many thanks ! Have a good day!
Could I ask below?
How to do?
- FURRYe38Nov 03, 2019Guru - Experienced User
abcchana wrote:
Hi Furrye38,
Could I ask below?
How to do?
Under Basic tab/Wireless settings.
A factory reset maybe needed to ensure any recent FW updates are installed correctly and any mis-configurations are cleared out. After setting up, you can do a back up configuration to file for safe keeping. Under Advanced tab/Backup.- abcchanaNov 03, 2019AspirantHI furrye38,
Thank you again but I could only enable/disable 20/40Mhz Coexistence.
How can I Set 20/40Mhz Coexistence to 40Mhz only?
Many thanks
