abcchana
Nov 02, 2019Aspirant
Satellite office RBR50
Hi all, my satellite of RBR50 is sometimes offline / discount but the main one (mother) is still online. I have diabled any power saver setting. And the discount happens with no pattern Is it du...
Nov 03, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
I
Is it due to the hardware problem? I still get warrant. Could I know it is possible to exchange the new satellite? and now is the process? Coz my call/help service were already expired.
Many thanks
