NigelHorne
Nov 17, 2019Aspirant
Satellite only connects at 2.4ghz
I have my router in the basement, a satellite on the first floor and two on the second floor. The network map shows the first floor connects at 2.4 only. Why? It is directly above the router, very clo...
Retired_Member
Nov 17, 2019What difference does it make? Is everything working?
If you're seeing this through the app, there are reported problems with the app.
- NigelHorneNov 17, 2019AspirantThe app has a yellow icon against it rather than green.
