NigelHorne
Nov 17, 2019Aspirant
Satellite only connects at 2.4ghz
I have my router in the basement, a satellite on the first floor and two on the second floor. The network map shows the first floor connects at 2.4 only. Why? It is directly above the router, very clo...
Nov 17, 2019Guru - Experienced User
try moving it further away. the satellites should be at least 30 ft from each other and the router. minimum.
