hollang
Feb 22, 2019Tutor
Satellite only connects with 2.4Ghz RBK 53
not sure why, but my 2 orbi satellites only seem to connect to the base unit via 2.4 GHz band and never the 5 GhZ one which I think is supposed to be faster, isn't it? any suggestions on how to addr...
ekhalil
Feb 22, 2019Master
hollang wrote:
not sure why, but my 2 orbi satellites only seem to connect to the base unit via 2.4 GHz band and never the 5 GhZ one which I think is supposed to be faster, isn't it? any suggestions on how to address this?
- The main wireless backhaul link uses DFS channels (Dynamic Frequency Selection). Orbi is obliged to switch to other channels if it detects radar signals on the DFS channels. If you live in an area close to an airport, military base or a weather radar you can have high level of radar signals on the DFS channels and this can happen.
- There are some wireless routers' vendors who do not follow the DFS regulations. You can have neighbors who use such routers and are transmitting on the same channels as your Orbi's backhaul which will force Orbi to switch to other channels.
I would suggest the following to troubleshoot this issue:
- As suggested by CrimpOn above, please first check the Attached Devices in the web GUI and confirm that your Satellites show Connection Type 2.4GHz and not 5 GHz
- Make a wifi scan to check which high 5 GHz channels (channels 100 - 140) are being used by your surrounding.
- There is also a telnet file that logs the radar detections. Please follow the following steps to print your radar detection logs:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the command:
- root@RBR50:~# cat /var/radardetect.log
