mith_it
Aug 31, 2018Luminary
Satellite only connects with 2.4Ghz
This is very strange, I've had my Orbi system for a few months now and it worked fine until 2 days ago. I have the router and 2 satellites, one is wired and one uses the wireless backhaul. The wirele...
- Aug 31, 2018
swap out the wired satellite for the wireless satellite and see how it goes.
Aug 31, 2018Guru - Experienced User
RAIOJR
Sep 01, 2018Aspirant
How can you cheack to see it your on 2 or 5 ghz?
- mith_itSep 01, 2018LuminaryYou can see it in the interface of the router. If you use the app, at least on iOS you only see a colored dot next to the satellite, it changes based on the quality of the connection, green is good, in my case I saw magenta which means poor.
- FURRYe38Sep 02, 2018Guru - Experienced User
Hope you might be able to get a replacement. Ask for am RMA.
- Christian_RSep 04, 2018NETGEAR Employee Retired
