mith_it
Aug 31, 2018Luminary
Satellite only connects with 2.4Ghz
This is very strange, I've had my Orbi system for a few months now and it worked fine until 2 days ago. I have the router and 2 satellites, one is wired and one uses the wireless backhaul. The wirele...
- Aug 31, 2018
swap out the wired satellite for the wireless satellite and see how it goes.
mith_it
Sep 01, 2018Luminary
You can see it in the interface of the router. If you use the app, at least on iOS you only see a colored dot next to the satellite, it changes based on the quality of the connection, green is good, in my case I saw magenta which means poor.
Sep 02, 2018Guru - Experienced User
Hope you might be able to get a replacement. Ask for am RMA.
- Christian_RSep 04, 2018NETGEAR Employee Retired
- mith_itSep 04, 2018LuminaryThank you Christian_R, I'll follow up when I get home and can check the serial number.
